RE: Official Parkzone Extra 300 thread
there is what one guy said here is a thrust problem what might be happening is normal setup for me for madiens is a little up elevator and a little right ailerion just for torque but i think this bird has a to much thrust up angle one man here said he added two washers on his and now its level flight i agree with that go level flight then juice throttle the plane goes up attitude.over all my madien was good.this plane needs very little speed to come off grouind and it goes straight with rudder on take off.because two people flew before mine and i saw all the lg problems i decided to hot glue the base lg in place before putting wire on and paints one screw on the pants was stipped even before i went to fly it.i was going to put locktite on put with a stripped screw i put a blind nut in and i was able to maiden with the pants.the futre i will take the pants off to much trouble with tip overs go with collets and keep wheels the same or just slightly larger.i am so glad for this bird rather than the me109 i had garbage plane.the me109 i saw today made my a** muscle tighten up today.stay away from that i went thru two of those before i said ok.one man noted a gemini we fly that to and to tell you the truth that plane is awesome to land the lighter the wieght the better it will fly and you can land it on a postage stamp if nned be.good luck and happy flying to all.
foam the new wood hot glue the new ca just kick it
