RCU Forums - View Single Post - Trimming Help
Old 06-28-2010 | 11:53 AM
rcpattern
My Feedback: (45)
Default RE: Trimming Help
ORIGINAL: cmoulder
Mine requires significantly more push than I'd like when inverted, and also requires significantly more than 2% down mix at idle (although I don't have a mix yet) for downlines, so I am thinking of reducing the wing incidence a little.
Does this sound right? Stop me before I do something idiotic. Again.
Bob,
If the plane flies fine every where else, but you have to push a little harder inverted try either lowering the amount of expo on down elevator, or increasing the throw slightly if you are already running very low expo. Use the expo and rates to give you the feel you want.
My Focus II that my brother currently has is pretty close to .5 positive
Arch
