If the plane flies fine every where else, but you have to push a little harder inverted try either lowering the amount of expo on down elevator, or increasing the throw slightly if you are already running very low expo. Use the expo and rates to give you the feel you want.
My Focus II that my brother currently has is pretty close to .5 positive
Arch
Thanks, Arch! I will keep this in mind as well while I work on the trimming.
