RE: Slow stick V-tail problem
Backdraft you have it backwards!
When you push you're stick to the RIGHT:
you're left control surface should move UP and "to the right" and you're right control surface should move DOWN and also "to the right"
Stick to the LEFT:
You're left control surface should move to DOWN and "to the left" and you're right should move UP and "to the left"
When you push you're stick UP:
both surfaces should go DOWN.
Push your stick DOWN:
both surfaces should go UP.
