setup help 9chp on 4 aileron bipe and twin elevator servos
I am working on setting up my aeroworks 50cc ultimate on my 9CHP. I checked the FAQ page on Futaba website and figured out how to do the four aileron servos, it stated: Use Flaperon setting, channels 1 & 6 give you first wing right and left aileron, channels 7 & 8 give you upper right and left ailerons. Then mix channel 1 to 7 100% with trim ON so aileron trim adjusts both servos. Then mix channel 1 to 8 100% with trim ON so the aileron trim adjusts both servos. Lastly, I need to go to auxiliary channel screen and set channels 7 & 8 controls to NULL to keep them channels from being moved accidentally. PHHHEEEWWW! [&:]
The problem that I am having is that I already setup the elevator using Ailervator setting utilizing channels 2 & 8. See above paragraph where it says to use channel 8 for upper left aileron.
How do I setup my dual servo elevator assuming I will use the Flaperon setting for the 4 aileron servos as described in FAQ on Futabas website?
Thanks for any helpful replies in advance!
Craig
