RCU Forums - View Single Post - Portable Generator
Old 06-29-2010 | 09:29 PM
afterburner's Avatar
afterburner
My Feedback: (18)
Default RE: Portable Generator
I bought the Honeywell 2000 as well when it was all over RCU. The Honeywell like the Honda is an inverter type which has a clean sine wave. If you are going to use the generator for powering a 12 vdc power supply so you can use your 12V chargers, you should check to see if it works. If the AC is dirty and/or clipped, your 12 volt supply may intermittently keep shutting down giving you problems.
Marty
