ORIGINAL: darylm44
Got back after a 3 week trip and finished the Focus Sport. I have flown it 3 days last week and all I can say is wow!! It has unlimited vertical with the Magnum 120 and flys strait as an arrow. I had a little bit of a learning curve with the Perry pump. I hooked up the line from the muffler to the tank to pressurize it. Wrong, I had fuel spitting out of the carb all over the plane. Disconnected the pressure line from the muffler and adjusted the flow down wards and it is working fine now.
It is a shame they are not making this plane any longer. I would certainly recommend it!!!!
I am glad to see that the Perry pump worked out for you. I would presume that it is the "VP20" pump. I see that you discovered that you do not use muffler pressure with a pumped engine. Some folks still argue about this. Enjoy your awesome bird, I have 7 hours on mine now, and it just keeps getting better.
-Robert
