RCU Forums - View Single Post - Loose muffler solution
Old 06-30-2010 | 06:54 AM
coralcape
Default Loose muffler solution
Have a .46 evolution, that the rear end of the muffler would come loose after a short run even after torquing the long screw and double nutting the end. Found that the long screw gong thru the muffler was expanding when hot. I ran the engine 'till hot then retightened the screw and problem solved. Good luck, red
