RE: Programming AirField F-16 70mm ESC
Thanks for the info Opjose. It looks to be somewhat difficult, but I will see what I can do. Also, would that programming card that I have the link for in my first post work with this ESC?
I am just using the stock battery, but even found it too nose heavy with that. I have added some weight to the bottom of the tailcone and adjusted the linkages and now she flies great. I love this plane. How big of a battery are you using on it? Are you just using one with more MAH or are you using one with more cells?
Again, thanks for the info.
