RE: The Evader Coalition ~ T.E.C.
I swapped out the 81t spur for an 88t version, so hopefully that will compensate for the larger tires. I'm not sure I'm willing to drop the suspension lower - after all, improved ground clearance was the whole point of the big tires. I may just see if going back to negative camber will help. It should in theory, but practice will prove it out.
