RCU Forums - View Single Post - Cheap Plastic Cowls
Old 07-01-2010 | 06:51 AM
outdoorhunting
Default RE: Cheap Plastic Cowls
Remember not to make the reinforcement too thick (it could make the inside diameter too small). It's always a good idea to do this AFTER you have made the cut outs for cyl head, needle valve, etc. That way, if you're off a little bit on a cut, it will be easy to fix. Good Luck !!
