RCU Forums - View Single Post - Viper Jet 2M Pointers/ tips.
Old 07-01-2010 | 06:58 AM
  #164
Bill Hatcher
Default RE: Viper Jet 2M Pointers/ tips.
Jjet, There is no rear tray that comes with the kit. If you want one you will need to make it up your self. Here is the one I made up. As you can see there is not much on it. If you are going to use the cockpits you will need to keep every thing to the sides. Since we mounted the cockpit in the front a little different than what the instructions call for we had to cut some of the bottom of the front one for clearance for the receiver. There is not a lot of room under the cockpits.
