RCU Forums - View Single Post - Correct way to install a prop
Old 07-01-2010 | 07:32 AM
Backdraft83
Default Correct way to install a prop
I have a <span class="headingb">TowerPro BM2409-12T outrunner and sometimes I'm having a bit of trouble getting the prop
correctly aligned on the shaft. It could be the nuts that I'm using or the thread at the end of the shaft...regardless of that, I wanna make sure I install it correctly.
Dont know if theres any other way to install a prop
nut - washer? - prop - washer? - nut
I screw on the first nut all the way to the end of the thread and tighten it (if its possible). Usually leave the first washer out so I can make the shaft as short as possible.
The first time I installed a prop on this motor, I didnt use the first nut and just tightened the prop against the motor hub,
later I realized that it was pulling the motor shaft and the washer at the other end was grinding against the bearing, so it was
losing alot of power. The benefit was still that I could do a nose landing and the shaft would be just fine. I mean these things are really soft, doesnt take much to bend them. Wish they would make them so that the thread goes all the way to the hub.....
</span>
.....all tips are welcome
Thanks in advance
</span><span class="headingb">Edit: Are locknuts mandotory on a motor like this? When they wear out I've just used regular ones.</span>
</span>
