RE: Idleing
My first thought is about the same as Dave's.
It assumes the engine idles fine at the speed you want but the trim lever is not centered.
The throttle pushrod needs to be slightly longer or shorter so you can have the trim fairly centered when it is idling at the speed you want.
Carrell
