RCU Forums - View Single Post - Throttle arm plate
Old 07-01-2010 | 11:09 AM
arobatx
Default RE: Throttle arm plate
You are fine...the spring helps keep the plate centered in the carb bore. Without it the vibrations could eventually wear the mating surfaces and cause problems for you. Leave the spring, don't worry about it no longer closing the plate
