I see lots of comments regarding the spring, and stress on the servo in various threads. Those curious should fit an amp meter between the throttle servo and receiver, measure the current draw with and without the spring catch on the arm
I've only seen a select few carbs with significant spring tension on engines we use. The difference, if any noted at all, isn't worth removing the spring catch from the arm, in most cases.
