RCU Forums - View Single Post - HPI MT 2
Thread: HPI MT 2
Old 07-01-2010 | 06:34 PM
SyCo_VeNoM's Avatar
SyCo_VeNoM
Default RE: HPI MT 2
ORIGINAL: Kacy
The flywheel from the .15 fe will not work.You will have to buy HPI part # 86021 its a flywheel for a mt2 18ss,which would also be a good time to upgrade to the racing clutch #87191 and you will have to get the 13t clutchbell #77103 and savage spur gear #87138 set up.There is also a spring setup that creates limited slip differentials #72215.Doin all of these mods may require the use a different engine mounting holes and mounts.I have not completed this swap yet as Im waiting for a few things to come in to gt it done.Do a search for the mt and you will find someones post about all the upgades that can be done to it.
isn't that for a g3.0? T3.0 should use the same mounting holes built in as a T-15 seeing there supposed to be the same mount points. I don't own the T3.0 but according to its specs the measurements are the same as the T-15.
