RCU Forums - View Single Post - Software Update Version V 2.30
Old 07-03-2010 | 11:55 AM
stevebeale
Default RE: Software Update Version V 2.30
Hi all
After re downloading the Giga Program and firmware again to day, I re flashed one TX module and one 8 ch micro, this time i added the voc file to the TX sd when flashing,
and all seem to work , no firmware errors, I will say Binding is very hit n miss, it seems to take several attempts to bind each receiver, also not having any UK instructions
im not certain if any of the procedures have changed, But im finding switch on TX press and hold button 2 until steady green on off,( if you press button 2 to late the red error led stays on and you get a error beep) then power up receiver and use binding plug i find im having to use bottom pair of pins on micro (red black) as before i could use either. This could be me,, LOL
and also it know loads model files ok,.. I cant see how i could have flashed 2 TX and 10 receivers wrong before so i can only conclude :
1 the gigas 2.30 was changed went it went of line for a working version
2 the voc file was missing from the tx sd onthe first flash up
3 the first downloaded files were corrupt
i have no clues but for know things are working
is the DE voc in German do we need a EN.voc file
Steve
