RCU Forums - View Single Post - when transmiter is set to 70/30 it takes off backwards
Old 07-03-2010 | 01:30 PM
SyCo_VeNoM's Avatar
SyCo_VeNoM
Default RE: when transmiter is set to 70/30 it takes off backwards
its usually pretty simple to recalibrate ESC's
I'm guessing you have the VXL if so read this post for 2 years ago http://rcudev.rcuniverse.com/forum/fb.asp?m=7782241 it has the steps to recalibrate it
and Savagejim its not really strange he went from 50/50 to 70/30 the trigger goes farther forward which would be reverse from its stock 50/50 setting. I've had it happen on every radio I own when I swapped the throttle ratios and its fix is always as simple as recalibrate the ESC
