2.5 Diesel Thread up from the vaults
and revived!
Pe Reivers recently sold me a new Piston and liner set for an MVVS 2.5 cc diesel I acquired "pre-loved" (from an old gentleman who sadly is very ill). It appeared to have very little use though the piston and liner in it felt awful when turned over and would not hold compression. It was sitting neglected and sad when I collected it
The engine stripped, cleaned and assembled with new piston and liner and placed on a test stand today. Purpose - first start and running in.
Fuel: 25% Castor Oil; 35% Di-Ethyl Ether; 1.5% IPN; balance lighting grade Kerosene.
After a few minutes flipping and gradually screwing down the tommy bar, it started to pop. Open exhaust - no silencer fitted (I do not fit silencers to engines I am running in).
A quick touch of the electric starter - and it was away. Brrrp ....brrrrp .... brrrp running very rich (3 1/2 turns out on main needle)
Several very rich 5 minute runs followed. Complete cool down to ambient temperature between runs. Engine starts to feel "bouncy" as the moving parts bed in. Still can't hand start it though. Compression feels good.
Contra piston is an extremely tight fit. I use my "broomstick" handle compression adjuster to turn in the compression screw. There is no blow by leaking out past the compression adjusting screw. These MVVS engineers and machinists know their business.
Lean out to rich max RPM and adjust compression carefully for best running. Back off 1/16th turn. I lean it out to see if will hold a peak. All is good. Quickly richen up. Try R/C carb. After screwing out the air-bleed adjustment screw to max, it throttles like a good glow engine.
One VERY happy MVVS small diesel owner. Onlookers (mostly electric flyers) are impressed.
Basic data :
+ Temp: 13c
+ Elev. 200 meters AMSL
+ Humidity 65
+ Barometer Not Known
Engine
MVVS 2.5D "Blue Head"
Propeller: Bolly Clubman 8.5 x 4
Fuel mix: As above
Max RPM after several tanks (run in not yet complete): 12,500 on R/C Carb fully open
Min - not checked (engine not run in nor settings optimised)
