My big stik with Saito FG-20 Gas engine
Hello, this is my big stik 60
Specs are:
Great planes Big Stik 60
Engine: SAITO FG-20 running stock ignition and with motul oil and 15x8 menz propeller. Ignition is located externally under the fuse. I will be trying a 16x6 soon.
Battery: a123 1000mah for ignition and 1950 FAUP for RX
RX is a futaba 7 channel FASST
Landing Gear: custom carbon Fiber with William Brothers balloon wheels 3-1/2ยดยด. Tailwheel ohio superstar with a dedicated servo.
Sullivan tail wire
Servos are futaba s3001 for everything except ailerons, where I put something a lttle better. Rudder and elevator servos are mounted on the tail for balancing. It is a little tailheavy but inside the limits.
on a 12oz fuel tank it flies for 30 minutes or more. this engine is very nice.
the firewall was reinforced with fiberglass.
