RE: ***My first 46 Custom Gasser with PICS and VIDS***
...whats Davey Jones locker??? Im guessing its another term for the deep blue??? The flex cable cannot
slide out of the strut housingas it soldered to the prop shaft. The prop shaft has a flange on it that sits up
against the new high speed bearing I have installed in the strut housing. To remove the flex cable you can
either pull it out from inside the hull or remove it, the strut, prop, dog etc all in one piece by removing the
one nut and boltthat holds the strut ontotransommountas it is pictured. It will come in very handy when
I want to pull the entire drive train out to clean and service it.
