RCU Forums - View Single Post - What should I have done?
Old 07-04-2010 | 11:29 AM
nrad2000
Default What should I have done?
I have successfully flown the Escapade for a few month. I was able to comfortably do loops, rolls, some hover, and stall turns. Of course all this is done really High in the Sky. Landings were never a problem. Most of them were nice and smooth. a couple were bouncy. Yesterday, I was practicing more aggressive landings. I would come in parallel with the runway about 15ft off the ground, turn really tight to bleed off most of the speed, level the wings and used Rudder to align with the runway, and touch down. I was able to do that twice successfully. The third one was looking really good. Even better then the 1st two. But this is when it happened. the wheels touched ground and the escapade bounced up 2 - 3 feet. Right wing looked like it began to stall. I gunned the throttle to redo the landing. The escapade continued to suddenly Roll Right, was almost inverted facing away from me, and hit the ground nose first.
Question:
1) what I experienced was a torque roll?
2) if the wind did stall what should I have done? Or, maybe there was nothing I could have done?
Damage assessment:
The engine and it's firewall was ripped off, the canopy broke in two, the right side of the plane where the canopy would sit on is gone, and the left wing leading edge (about a foot) is gone. The firewall and fuselage I can repair (need to refab some parts). I'm more worried about the Left wing.
