Hi!
Definitely a stall! No torque roll! That doesn't exist with small glow powered planes!!!!
You would have two solutions! First one is... cut throttle and at the same time give down elevator and left aileron and as soon as the plane levels of ...give slightly up elevator and land.
Second is... give full throttle and quick down elevator and left aileron ....as soon as the plane levels off...give up elevator and climb!
This sounds easy in theory but if you are close to ground it becomes very tricky to perform
So the best advise is to practice so that you newer come in that situation.
