Agree...quite fixable, using ust the ideas/methods Dr1 suggests.<div>
</div><div>One thing I might toss in as well...</div><div>
</div><div>As you repair/reinforce the firewall area, you may use thinner wood in one area, or thicker in another, different kinds/amounts of glue, etc etc. All of this will likely change the weight a bit, making rebalancing necessary. </div><div>
</div><div>If those weights currently installed will be tough to get to after the repairs, might want to pull them while it's easy.
</div>
