RCU Forums - View Single Post - Elevator mixing
Old 07-05-2010 | 07:18 PM
basman
Default Elevator mixing
I want set both Elevators adjustment on the tirm tab on the radio? Currently I fly with DX7 and have the left elevator on ELEV channel and the right elevator on AUX2 on the receiver.
They are mixed on number 1 mixing Elev - Aux2 ON
Rate +100%
+ 100%
SW : ON
Offset : +1
When I am in flight if I adjust trim then only the left elevator moves, is there a way to have both moving on the trim tab so you can adjust equal amount in flight ?
I don't like using the Y leads with the reverse set up as I have seen them go out of adjustment due to heat on a sunny day.
Brian
