RE: pulling the thread
Hey Rapptor, get a life instead of trying to mask an obviously excellent line of turbines and incredible service. I can't recall ever reading anyone having a problem with Eric other than you, maybe you are the problem. I don't even deal with the canadian rep because of how well Eric is with his customers. It pisses me off when your info. is completely false and could prevent someone from having an excellent experience with the purchase of a turbine.
As for fuel consumption, my rabbit from startup to shutdown which is about 8 min. and I am on the throttle alot (about 60-70% of flight at full throttle) and I use about 1.5-1.75litres. The new cheetah is suppose to be as good or better for its output. The cheetah has a 2 second spool up and my rabbit is definitely just under 3 seconds from idle to full. The new kero start rabbit has a new diffuser and Eric commented it is now 2 seconds for spool up.
