Question on props
it won't let you fly slower. the benifit is you will have more thrust at lower rpms if you happen to need it. the downsides are that they are less efficient at higher rpms (the kind that your .40 size 2 stroke will crank out) and always seem to be in the way when you try and work on your engine.
