RCU Forums - View Single Post - DLE30!
Thread: DLE30!
Old 07-06-2010 | 04:53 PM
  #3348
captinjohn
Default RE: NEW DLE30!
In the changing of the piston ring, all I did was loosen 4 cyl base allen head bolts. Remove sleeve. Removed standard ring and placed new ring on piston. A little lube...back together...let the sleeve center just before tightening the 4 allen base bolts. Done. The engine has good feel to it. I did along the line prime it with fuel mix...it acted like it wanted to go...but no no no no no no no no go. This is crazy. Had it apart before and several engines apart. They started right up. I have no way to eclectic start it....because I never needed a electric starter.
Had to edit this a little....whenany engine does not start....I get crazed!!!! Capt,n
