CopterX CX 450PRO V3 Belt Version 2.4GHz RTF
Hello,
any reviews on this item?
I want to buy this piece, but I'm not sure if it worth the money...
I would like to get some opinions here...
the info about this heli is:
CopterX CX 450PRO V3 Belt Version 2.4GHz RTF (Cartoned)
Features:
* High strength rotor hub for high rigidity and stability
* Aluminum alloy main rotor bearing block with one piece servo mount
* Single piece integrated design composite material anti-rotation guide and gyro mount
* High strength one piece landing gear
* Full aluminum alloy main rotor system
* Fully ball raced for accurate and precious control
* Composite materials battery mount with canopy mount for better weight distribution
* Carbon fiber one piece high strength frame
* User friendly belt driven tail rotor system
* Weighted tail rotor blade holder for more accurate rudder control
* Inboard rudder servo mount for improved CG
* stream line light weight canopy with transparent window
* Fully ball raced for ultra smooth operation
* One way bearing auto rotation system
Specification:
* Length: 635mm
* Height: 230mm
* Main Rotor Diameter: 710mm
* Tail Rotor Diameter: 158mm
* Motor Drive Gear: 14T
* Main Drive Gear: 150T
* Autorotation Tail Drive Gear: 106T
* Tail Drive Gear: 25T
* Drive Gear Ratio: 1:11.5:4.24
* Weight(w/o power system): 470g
* Flying Weight: Approx. 780g
Package Included:
* CopterX CX450PRO V3 Belt Version Kit x 1
* CopterX 3550Kv Brushless Motor x 1
* CopterX 50A ESC x 1
* CopterX 2.4G Transmitter & Receiver x 1
* CopterX 9g Servos x 3
* Fusonic 9257 Servo x 1
* CopterX Gyro 240 x 1
* Full Size Paper Case x 1
* CopterX Balance Charger x 1
* Switching Adapter x 1
* CopterX Li-Polymer Battery 11.1V 15C 2200mAh x 1
* Instrustion Manual CD x 1
* CopterX Transmitter Config Program CD x 1
Thanks a lot,
Michael P.
