RCU Forums - View Single Post - Flight control article workshop
Old 07-07-2010 | 12:44 AM
  #39
marineA4
Default RE: Flight control article workshop
Hi Oliver,
Thanks for your response! I'm a bit unprepared as I did not take a real look at the numbers you need.
Right now one of my wings has the servo installed and the other doesnt. I've not installed the hi tec servos I plan on using.
Also, my JR servo still attached to the wing is stuck in the down position which it never reached full deflection.
Maybe I can give you the data to the failed servo and then install the Hi Tec servo and give you that data as well. I'd have to complete that project tomorrow as its late here.
I will post the data here tomorrow after work.
