RCU Forums - View Single Post - Push Rod Size?
Old 07-07-2010 | 11:32 AM
opjose's Avatar
opjose
Default RE: Push Rod Size?
ORIGINAL: LNEWQBAN
Hence, a 2-56 threaded rod that is properly supported along its length is safer and keeps the control surface more firmly in position than a 4-40 threaded rod that is not.
So true.
You prevent flex and buckling this way, which in turn reduces flutter and helps centering.
A thicker control rod does not necessarily get rid of lateral rod movement... but supports WILL.
