There hasn't been much new information released on the SD-6G lately. Out of curiosity, I went poking around at
www.sanwa-denshi.co.jp and found out a few things using Google translation:
-The SD-6G will have 8 character model naming
-The SD-6G will offer dual rates and expo on RU as well as AI and EL
-The SD-6G will use 6 "AA" batteries instead of a standard transmitter pack
-The SD-6G will offer graphic display of its 5 point throttle curves and 5 point pitch curves
-The SD-6G will support nine different kinds of swash plate
I would have preferred a standard transmitter pack battery myself, but perhaps it can fit a 2S LiPo or the NiMH pack from the SD-10G.
Overall, the SD-6G is shaping up as a really strong offering at $179.99. Hopefully "Summer 2010" doesn't mean September 20th and we'll see these in the near future.
One last note - if any of this information turns out to be incorrect, it's Google Translation's fault and not mine!
厳しいフライト環境へのニーズに対 した、ヘリ/飛行機用プ*ポ。 To address the needs of demanding flight environment, helicopter / airplane for radio.
COMING SOON! COMING SOON!
SD-6G の特殊装備 SD-6G special equipment
共通機能 Common feature
●2.4GHz FHSSスペクトラ 拡散方式 ●64x128 ルドット液晶 ●レンジチェックモ ード ●モデルメモリー(10モデル) ● トレーナーシステ (SDシリーズ) ● イレクトモデルセレクト ●デジタルトリ ●フェールセー (電波) ●*ーバッテリーアラー ●タイマー(ダウン/アップ) Spread Spectrum 64x128 ● 2.4GHz FHSS ● Memory ● ● Model Renjichekkumodo full-dot LCD (Model 10) System Trainer ● (SD Series) Digital trim ● ● Dairekutomoderuserekuto fail ● (radio) Robatteriaramu ● Timer ● ( down / up)
●データリセット ●データコピー ●モデルネー (8文*) ●エンドポ ントアジャスト ●センター ●リバース ●ス*ッ ルカット ●C-MIX(2系統) ●6セルDRYバッテリー仕様 Data Copy Data Reset ● ● Model Name ● (character 8) ● ● Center cut throttle Endopointoajasuto ● ● Reverse ● C-MIX (2 systems) 6 ● DRY cell battery specifications
飛行機(グライダーを含む)用機能 Aircraft (including gliders) for feature
●フライトモード(3系統) ●デュア レート(AI, EL, RU/フライトモードx2系統) Flight Mode ● (three strains), dual-rate ● (AI, EL, RU / flight mode system x2)
●エクスポネンシャル(AI, EL, RU/フライトモードx2系統) Exponential ● (AI, EL, RU / flight mode system x2)
●ス*ットルカーブ(5ポイント グラ フ表示機能付) Throttle curve ● (5 points graph display function)
●フラップ → エレベーターミ*シング(フライトモ ドx1系統) ●Vテール ●デルタ ●デュアルエル*ン ●フラッペ* (フライトモードx1系統) Elevator Flap mixing → ● (x1 flight mode system) ● V ● Delta flaperon Dyuarueruron ● ● Tail (x1 flight mode system)
●エル*ンディファレンシャル(フラ トモードx1系統) ●フラップ(2ポジ ョン) Erurondifarensharu ● (flight mode system x1) flap ● (2 positions)
●エルベーター(エル*ン、エレベー ーの複合新機能) Erubeta ● (aileron, elevator complex new features)
●デュアルエレベーター ●ダイレ トトリ メモリー(ACT/INH) ● Dairekutotorimumemori dual elevator ● (ACT / INH)
ヘリ用機能 ● フライトモード(3系統) ●スワッシ プレートタイプ(9タイプ対応) ● for helicopter flight mode feature (three strains) Suwasshupuretotaipu ● (09 types supported)
●デュアルレート(AI, EL, RU/フライトモードx2系統) Dual-rate ● (AI, EL, RU / flight mode system x2)
●エクスポネンシャル(AI, EL, RU/フライトモードx2系統) ●ジャイ*(フライトモードx2系統) Exponential ● (AI, EL, RU / flight mode system x2) gyro ● (flight mode system x2)
●ス*ットルカーブ(5ポイント グラ フ表示機能付/フライトモードx2系統) Throttle curve ● (05 points graph display function / strain x2 flight mode)
●ピッチカーブ(5ポイント グラフ表 示機能付/フライトモードx1系統) Pitch ● (05 points graph display function / flight mode system x1)
●レボリューションミ*シング(3ポイ ント/フライトモードx1系統) Reboryushonmikishingu ● (3 points / flight mode system x1)
●ダイレクトトリ メモリー(ACT/INH) Dairekutotorimumemori ● (ACT / INH)
