RCU Forums - View Single Post - Bell 47 Crash
Old 07-08-2010 | 01:04 AM
  #51
yacsf
Default RE: Bell 47 Crash
ORIGINAL: lawrencelkl
Hi all,
some updates from me. the engine did not get to idle well and only run when the choke was partially opened, will die out immediately when choke fully open. Engine was stuggling to lift at all, and seems very hot.
as suggested by Glenn, i cleaned the carby and all changed. this is the video taken after the carby is cleanned.
Thanks a lot folks!
http://www.youtube.com/watch?v=q9MZr6MS4gg
Lawrence
Hi Lawrence,
Beside replacing the caskets for the carb. You need to check the engine compression. Check your piston and piston rings which cause the choke cannot fully open to run the engine smoothly.
