RCU Forums - View Single Post - Flight control article workshop
Old 07-08-2010 | 09:47 AM
  #48
olnico's Avatar
olnico
Default RE: Flight control article workshop
OK Orlando,
I've loaded the worksheet with your data.
Everything pretty much depends on what kind of servo travel you are using.
With a +- 30 degrees travel you need a servo arm of 5 cm and the maximum torque required is 190 oz-in:
With a +- 40 degrees travel you need a servo arm of 3,7 cm and the maximum torque required is 133 oz-in:
