RE: Software Update Version V 2.30
Eray
ok you probably wont get 2 beeps as they come from my FF9 you just need to get the timing right on pushing button 2 on the TX if your to late after the switch on test sequence the red led comes and a constant beeb from the WEA TX i find if i press and hold button 2 as soon as the yellow test led goes out the TX goes into bind (constant single flash green led) then for fast bind same prosess but a short push on button 2
steve
