ORIGINAL: sunraywest
do you have any spec on the delta that might be in the column
The column does have the specs:
Wingspan 54"
Area 700 sq. in.
Length 63 1/2", (43 3/8" disassembled)
Weight 7 3/4 lb. includes 8 oz. nose weight
Wing section root 64A014, Tip 64A215
Engine: 60
"Elevator, rudder, and aileron servos mounted in center wing. Motor servo in fuselage. Nose wheel operates off extra servo mounted in fuselage, runs on splitter wire from receiver rudder outlet. This allows easy wing attachment to fuselage at the field."
