RE: Need help IDing this engine..
I don'tnow about Fox, only have an old 35, but if the engine is cross flow and baffled, then the head turned might cause the baffle on the piston to hit part of the head instead of entering into the groove for the baffle in the head. Or, did Fox use a head button that could be properly located even if the head itself is rotated?
