RCU Forums - View Single Post - DX7 Mixing Ailerons and Elevators Together
Old 07-09-2010 | 08:46 PM
Glacier Girl's Avatar
Glacier Girl
Default RE: DX7 Mixing Ailerons and Elevators Together
John, first to have two servos on different channels on the rx you have to set up a mix where say left servo is master (channel # x), and right servo is slaved (channel #Z) for the elevator.
Then you would need to set two additional mixes, controlled by a switch on the tx to turn them on and off if need be.
One mix would be left aileron master, left elevator slave. Second mix would be right aileron master, right elevator slave.
And yes you can use the ailerons on a Y harness. As the mix is referencing the tx stick positions to make the control surfaces operate, not the actual servos. And yes you could also set the ailerons on separate channels too, just like the elevator, if you had enough open channels on the rx and an additional mix availability.
The manual will explain how to do it and assign both of these mixes to a single switch. The first mix is set up with no switch, and set to be always on.
You may have to play with the mix ratios as if the elevator is too aggressive it may make it oscillate as it rolls, ditto if it's to weak. As you are going to be using four surfaces to rotate the fuse on one axis.
