Originally posted by FLYBOY
Find the slop and fix it. Either your servo arm has slop in it, the servo is loose, the hole the rod in the servo arm is too big, the bend in the rod is flexing, the hinges are loose, or the control horn in the surface is loose. Not too many other things can cause it. Move the surface and see where the give is and fix that.
Hope that helps some
Hi FlyBoy,
It's in the aileron itself.
So far I have not installed the servo,linkage,etc.
When I hold that short rod that comes out of the bottom I can still move the aileron up & down appx 1/8th inch.
TH wants $110.00 for a new wing.
For a bit more then that price I can buy the full package TX RX Servos,etc but I have to many planes here now
