RE: CMP Edge 540-T .40-.50 size
Thanks for the tip on the tailwheel assembly, will have to get some of those
on my next Tower supplies order.
Opjose I am having a heck of a time with the elevator linkage on this one, once
I get both elevators centered with the stab, when I apply up the left or port side
travels higher than the right side, not good ! ! ! ! ! ! I have the servo mounted
as per the instruction booklet, might try turning it 180 degrees to see if that will
fix the problem, if not might go with 2 seperate servos but still keep them under
the cockpit.
What do you think the problem is and what might the solution be?
