RE: mounting saito .56 on nexstar
If you don't get any by tonight I'll take a couple and post when I get home. But you will see wasn't much to it really. There's not a lot of room to work with and unless you're really good at making bends you could do like I did. Mount the engine then using a long drill, drill through the mount and firewall where the control rod needs to be. A small z-bend at the throttle arm worked for me.
