Epoxy resin and Poly resin
Just curious,
Does Hardened (for a day or two) epoxy resin inhibit or retard the cure of Polyester resin? I just coated a FG part that I made with epoxy resin with Poly resin to give it a little more rigidity. The part had set for about a day and was sufficiently cured before doing this.
Just curious. I noticed that the resin in the cup had cured, and the little spots on the wax paper that had spilled were cured, but not the surface of the parts.
Curtis
