RE: ***My first 46 Custom Gasser with PICS and VIDS***
Mart, im now in the process of removing the clutch as most dont run one and believe it should give me a little more power
once the motor is run it properly. Im also going to change the drive train, increasing the length of the flex cable and removing
the round collet and only using the square drive. Im also going to install the ferrule on the flex cable. Im going to remove the
3/16th prop shaft and replace that with a 1/4inch one.
Ive also slightly modified the strut giving me the ability for more adjustment if required. Ill post up some pics and vids once
I have completed the changes. Im now just waiting on a few parts and my new 6717/3 prop which no doubt should make a
real difference on the water.
