RE: frequency up for grabs
<div style="text-align: justify">Thats right. There are several, I beieve 4, channels that exist between each of ours. They are usedfor commercial mobil use, if I recall. However, TV stations and radio stations' antennas can cause huge problems when filters and grounds come loose. They can spew noise all over the spectrum. You need the directional antennato track it down. Notify the owner and advise them that you have been harmed by there equipment failure and require it be repaired ASAP. IF they fail to react then threatena law suite or actually file one in small claims, (generally good up to 2500 bucks). Have every member start filing them. Suddenly fixing that loose wire seems the bargain. And you might pocket some coin for your troubles. The airwaves belong to us, the American people. Industry has no right to foul our band. Fight .</div>
