RCU Forums - View Single Post - Tamiya Gearbox Question
Old 07-14-2010 | 11:19 PM
BiggTony's Avatar
BiggTony
Default Tamiya Gearbox Question
Well, I'm pretty used to breaking in the HL gear box which is a very important step. As some of you know, I've finally got myself a Tamiya Pershing. I'm getting fairly close to installing the gearbox....but I'm not sure if I need to break in the gearbox. Is it still the same method using valve grinding compound or something else? Some of the gears have a chrome poslished finish and a very smooth surface. They looks as though grinding them down would be a bad thing. Same for the motor......this need to be broken in too?
Also the motors don't have disc capacitors......should they?
Thanks fellas!
Tony
