ORIGINAL: petera38
Hi guys,
Happened to see this thread, and thought I´d better take the opportunity to ask a couple of questions.......
I have been using 2 cells LiPo packs with my power box systems as well as my JetCat ECUs.
Having read horror stories about LiPos catching fire when charging etc. I seriously consider to use LiFe /A123 batteries in the future on my Jets.
Questions are: Can I use the 6.6 volts LiFe cells with the powerbox and with the ECU instead of 7.4 volts???
/Pete
If you send it to JetCat in Germany they change the mother board and the battery socket on the PC board is changed to a red one, the unit is then marked with 12v, if your turbine is a Kero start you need a three cell A123 battery to power up the plug.
Mike
