Too funny..Recent problems with new gassers...
Beam mounts are not good, need radial
Radial mopunts are not right, need beam.
Side carbs stick out too far, need rear.
Rear carbs stick out too far, need side.
Front carbs are too close to the prop, need longer hub...
Rear exhaust is too close to the firewall.
Side exhaust sticks out too far, need rear exhaust...
Engine is too heavy, should be lighter.
Engine is too light, need lead in the tail to balance.
Ignition takes too much power, need a heavy battery...
Factory supplied spark plug is no good, need a CM6, which is too expensive at most retailers, or not in stock.
Spark plug caps are too loose, need a hose clamp.
Spark plug caps are too tight, hard to remove...
4.8 to 6 volts means 7.2, ignition gets hot and quits...
And the beat goes on.........
