ORIGINAL: JsK
The Ve8 is not going to take the pounding a RC8Be will without upgrading the chassis to aluminum skids.
The only real weak spot on the RC8Be will be the rear hubs. If you run the upper hole they will last alot
longer. I would suggest silver springs F/R and the 1.1x10 hole pistons with 35wt oil.
ok, the RC8Be it is. looks like a great buggy to get into.
everyone seems to say tekin is the motor/esc to get. which one should i get and waht battery. thanks
