RCU Forums - View Single Post - Art-Tech Euro Fighter 2000 problems
Old 07-16-2010 | 11:56 AM
Rob2160's Avatar
Rob2160
Default RE: Art-Tech Euro Fighter 2000 problems
ORIGINAL: HighFi
Any suggestions? Iwould like to repair the plane but if this is a common problem Iwill just try a different model with a nice straight wing!
O, Ilive at 10000 ft above sea level so the thin air may have had something to do with it.
I just test flew mine today, CG exactly where the manual stated.. I did not have to put any weight in the nose..
I am a real world corporate pilot and if you are living at 10,000 Above Sea Level you will have some SERIOUSLY reduced performance in both the power output of your ducted fan and the lift generated by the wing.. at that altitude 30-40% as a ball park...
One thing I have done is replace the nose wheel with a slightly larger one, so it sits slightly nose high on the ground now, but this allows it to take off nicely from grass..
Hope you got it all flying! It is a fun machine to fly
